timgarman
Established member
Hi Folks
I've read a few threads on here about getting the most from the 500 engine. This seems to focus on four things, 1. Engine modifications, 2. Carb upgrade, 3. Exhaust upgrade and 4. Camshaft modification.
So (2) I've located an FZD 32/26 carb to go in at some stage and (3) I have a twin exhaust to add.
(1) I have little mechanical knowledge, but here's a list of the work I've had done by a local firm on my 500-F engine as listed on their invoice (which doesn't mean a lot to me). Clutch hasn't been touched yet:
Engine dismantled, inspected and measured.
Jetwash and hot tank parts.
Machine crankcase to fit O/S liners and wash block.
Check fit bearings and grind /polish crank, M-010", B/E-016".
Wash assemble and align pistons and rods.
Machine up 2 spacers to fit under new sleeves to set piston heights.
Remove two broken studs.
Face 4 cam followers.
Start assembling engine and set up crank and set up crank end float.
Overhaul oil pump.
Strip rocker gear and face 4 rockers, wash and assemble.
Strip, jetwash, bead blast head.
Remove one broken stud.
Weld exhaust manifold stud hole and remachine for stud.
Machine and fit 2 8mm helicoils to manifold faces.
Machine and fit 2 spark plug helicoils.
Reface valves and seats, mill wash and assemble head.
Assemble long motor and set tappets.
Listed under parts are:
Ring set
Regrind camshaft
8mm helicoil thread
Helicoil (spark plug).
Sorry that's a long list, and some of the terminology may be unique to New Zealand. But here's my question (finally). Whilst some of that work is necessary reconditioning, does it also cover the improvements to the engine and camshaft which will combine with (2) and (3) above to improve performance, without going mad?
Because the engine is still out of the car, now is the time to do anything else, if needed.
Well done, if you've read all that and have the time to reply! And thanks in advance
Tim
Overhaul oil pump.
Ring set
Regrind camshaft
8mm helicoil thread
Tim
