I rebuilt the generator using new brushes without electrical testing it. The car is just at the end of restoration so had never been run previously. When fitted to the car it didn't give more than a very negligible output even when tested according to Matt's Dad's excellent write-up.
I have removed the end plate to check the brushes and compared with the half worn originals. It appears that only the very tip of the brushes has been in contact with the commutator even though they are made with a reasonable attempt at the angle they will eventually wear to.
The question is, would this be likely to seriously affect the voltage output so is it worth me sculpting them to match the curvature of the commutator?
