Labman it is exactly the same as the one in this YouTube video. What is always missing is the double ended hex tool. I think it is 10mm and 8mm?
http://youtu.be/kpbXWbopfFo
Tony
I found one on eBay! It's on the way from Italy to the US.
Tony
The double ended small tube spanner is actually supposed to be 'missing' from a 500 tool kit.
It is present on the 124/125 tool kits - I assume it functions as an allen key to remove the twin cam rocker cover bolts.
Even though it looks somewhat incomplete without this tool, out of many dozens of Fiat 500's I have owned and worked on (including several 1 owner examples with untouched toolkits) I have never seen an original 500F kit with this spanner.
I have also sourced one from a 125 toolkit for display purposes on my 30,000 mile 500F but don't feel short changed if you don't have one!
If this is your toolkit make sure the wheel brace fits the bolts...
500 Sedans don't normally have the pointed end on the wheelbrace as they don't need it to remove hubcaps and wheel bolts are a 17mm head, usually the type with a flat pointed end is 19mm which will fit the Giardiniera or 126 wheel bolts.
Is this the correct kit? The guy wants a bunch of money for it but I'm considering if it is correct for a '70 500F.
Sent from my iPhone using FIAT Forum
Yes looks correct, so long as the wrench is 17mm, it does look smaller than the picture of the last one you posted. Also it has the wooden handled screwdriver which would be more in period for the 500F.
Yes- looks correct with the bonus of additional tube spanner! The wheelbrace should fit and screwdriver is correct- even the hinges on the box seem to be unbroken.. good find!
Very nice to see it back together again. Great work.
I'm actually debating on getting a 1973 fiat 500 or a 2015 Fiat 500 Abarth how do you like it so far?
