Pete145
Member
- Jun 2, 2014
- 288
- 85
I've just realised that my brake lights aren't working, and I suspect haven't been since the panel shop worked on my wheel arches and swapped my steering column ignition for the centre dash version.
The bulbs are OK, and the fuse is also OK (given that the other things driven by that fuse are working).
The Haynes manual doesn't reference the brake light switch. Does anyone know where that is and if it's likely that this has been disturbed as a result of the arch and ignition work?
Pete
Pete
