Berlinette
Member
- May 31, 2014
- 38
- 62
Can anyone please explain how the door hinges on a 1967 500F work. I need to dismantle to change the hinge pins. Presumably the first job is to remove the door card to access the door strap in order to release it from the door. The main issue I'm unsure about is how the hinges bolt into the A post. Are there captive nuts or do you have to access inside from the footwell to get to the nuts so they don't fall off?
