Thread Tools
Old 1 Week Ago   #721
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Re: Project Paolo
By the way, apart from the usual "adjust the position of the gear-lever" as a suggestion for reverse; maybe first check you have the rubber linkage bolt(s)in the correct way round/ washer correct.If you tighten it so that the linkages won't swivel, you can get syptoms like that; I wonder how I know?
fiat500 is offline Reply With Quote Quote
Old 1 Week Ago   #722
Re: Project Paolo
Damian if you watch this video from about 4.30 or about 5 mins you will hear the first gear whine. I apologise for the quality but I was trying to drive with a phone in my hand and my gear changes were rough because I hadn't driven the car for 15 years also you'll hear the trusted toolbox jiggling around.
Likes Paolo66 liked this post
Vitesse is offline Reply With Quote Quote
Old 1 Week Ago   #723
Re: Project Paolo
Quote Originally Posted by fiat500 View Post
By co-incidence, I was reading the manual for my Fiat 900e Amigo and find the threads for the belt mountings on that are listed as 7/16 x 20 UNF 2B; worth a try if you happen to have that tap available as it sounds possible given your quick observations.
Just reading the instruction manual and it confirms that the seat belt bolts are 7/16" - 20 unf which is the tap I bought.
Likes fiat500 liked this post
Paolo66 is offline Reply With Quote Quote
Old 2 Days Ago   #724
Re: Project Paolo
Just got to sort out a few electrical issues before putting him in for an MOT but electrics arent my thing and I'm stumped. I swapped the front side lights for orange indicators as a few people had problems getting it through the MOT. These used to have two wires going to them, one for indicators and one for side lights. As I am only interested in indicators I kept that wire in and put the side light wire into the small bulb holder in the headlights. When I switch the indicators on I cant get those lights to work. Side and rear indicators work but not the fronts. Also the indicator bulb on the dash is permently on and flashes as it should do when you indicate. Is it because I havent got a bulb in the headlight sidelight to complete the circuit? What type of bulb do I need for this?
Old 2 Days Ago   #725
Australia
Quote Originally Posted by Paolo66 View Post
Check that the indicators have a good earth connection I had similar wird behavour with lights that came down to poor earth connection
1500500 is offline Reply With Quote Quote
Old 2 Days Ago   #726
Re: Project Paolo
Quote Originally Posted by 1500500 View Post
I thought a bad earth at first but when I connect the two wires to the side lights the indicators work. It might be a bad earth making the dash light come on permanently though
Old 2 Days Ago   #727
Bleeding Knuckles has donated!
Re: Project Paolo
Damian, you may need to use a separate earth cable just for the purpose of the light, mine had to have to work correctly.
Ian.
Si dice in Sicilia non c'e nulla di piu pericoloso di una Donna con fucile da caccia.
Abarth - Piccola ma Wicked
Bleeding Knuckles is offline Reply With Quote Quote
Old 2 Days Ago   #728
Re: Project Paolo
Quote Originally Posted by Bleeding Knuckles View Post
Ian.
Agree with Ian. On the rear side of the indicator bulb holder, there is a little spade connector on the side. That is the earth for the bulb holder. As Ian says make a little earth lead up and connect one end to the spade and you can either break into the the black earth wire for the headlight and spur it off with a multi bullet connector there. Or simply put an eye connector on the other end of your new earth wire and secure it to the nut and bolt holding the indicator bulb holder to the body.
Mine originally had orange indicators as it's RHD and I just looked and it has both types I described above. I guess they were hedging their bets to ensure it didn't suffer any dodgy earths.
I can take a picture if you need one?
Old 2 Days Ago   #729
Re: Project Paolo
I wondered what that spade was for. Thanks
Old 2 Days Ago   #730
Re: Project Paolo
What about the light on the dash staying on? Any ideas?
What bulb type goes in the small holder in the headlight?
Old 2 Days Ago   #731
Re: Project Paolo
You will probably find that once you resolve the earthing issue on the indicator it may fix the dash light? If not it maybe a new flasher unit required. These flasher units are quite complicating inside and have a separate contact for the indicator lights themselves and a different contact specifically for the dash light.
If you return it to the original setup with the two bulbs in the indicator/side light does the dash light behave normally?
The bulb that goes in the headlight. I took mine out and it looks like a 4W bulb.
I think it's this one here? It just pushes into the headlight, no turning or anything fancy.
https://webshop.fiat500126.com/katal...-light-12-v_4w
Thanks Paolo66 thanked for this post
Old 2 Days Ago   #732
Re: Project Paolo
Hopefully the earthing will resolve the issues. I think the sidelight bulb is a type 233. Will work on it some more tomorrow
Old 1 Day Ago   #733
Re: Project Paolo
Connected two earth leads to the light units and now I have all indicators working as they should. Thanks all. Still have the light on the dash permanently on though. Am I right to assume this should be off and only come on when you select indicators? Waiting on some parking light bulbs to turn up to fix that problem. The small bulb holder for these also have a spade connector on them so I'm assuming that needs an earth lead as well?
Old 1 Day Ago   #734
Re: Project Paolo
Does the indicator light flash Damian when you select the indicators left or right?
My headlights don't have an extra tab like you describe, so it must be using the earth from the main/dipped beam. There must be a wire or metal strip from metal bulb holder for the driving light on mine up to the earth for the headlight bulb?
Old 21 Hours Ago   #735
Re: Project Paolo
Quote Originally Posted by Vitesse View Post
Yes it does Tony but when you deselect the indicator the light stays on. Is this right?
Thread Tools
Punto (Mk2/2b) Paolo - My old Mk2 Punto Wisey Members Motors 3 21-01-2013 17:38
(T) possible project? nikkiy9 Punto (Mk2/2b) 4 01-01-2013 17:17
Punto (Mk1) Paolo the MK1 Fiat Leopard (Punto) Ratlook. Coxy13 Members Motors 12 31-03-2011 00:41
Hello Coxy and Paolo Punto here :) Coxy13 Newbie Central 3 30-03-2011 16:02
