I went for larger at front smaller at rear with the standard master cylinder and brakes are great!
Haynes manual says 0.750 inch, which would be 19.05mm. On Passione500 supplier site they show 22.22mm (0.875in or 7/8in) for front and 19.05mm (0.750in or 3/4in) for rear.
Checked a few other suppliers as I am in a parts buying mode, and they all show 22.22mm for front and 19.05 at the rear.
John
Mine was the kit from AG 22 at front 19 at rear.Can you remember what diameters you went with Sean?
Keeping the original 500 sized master I think the idea is either 3/4 all round or upping the diameter of the fronts to 7/8 and reduce the rears to 5/8 (or metric equivalents).
The latter keeps the piston travel the same at the master whilst giving a bias towards front braking as is common on modern cars.
