I had a day off today as I had to take my car in for a service.
So this afternoon I decided to get on with the doors/windows.
Project 1/4 glass.
Stripped the door of all its components.
Found it easiest to undo the regulator, and drop the window.
Undo the 2 screws holding the 1/4 glass frame in the door and then pull the frame back and then slide it out.
Then remove window surrounds and then remove the glass.
I have purchased the good quality 1/4 glass frames, seals & rubber tape, new handles and various other little pieces.
Unfortunately I purchased the ones with the catch on the mounting bracket.
Not a problem, the frames are the same but I now need to buy 2 catch pivots.
So to refurbish them I first off drilled out the stainless steel rivet.
Then undone the bolt that tightens the clamp around the frame spigot.
Remove the inner frame from the outer frame.
Remove the frame seal and the upright window seal.
Clean the main frame up and give it a coat of paint.
The upright aluminium runner was a little corroded and pitted and needed some tlc. So I sanded it with some 240 grit and then rubbed it down with some 800 wet & dry in the same direction to give it a nice clean surface with a little abrasion. I was going to polish it, but as with all aluminium it will tarnish. So I opted to spray it with clear lacquer. If you polish it first then lacquer it the paint will flake off at some point.
I was quite pleased with the result.
Next was to refit the seals, I usually used a spray bottle with water and washing up liquid, this makes everything go in so much easier.
I think the next step is to fit the inner frame because if you fit the glass first it may not all fit inside the outer frame.
This is where I stop this part as the new rivets are smaller than the old ones. They literally go straight through the old hole. So I need to get my dad to make some new ones. Fecking pattern parts!
The removal of the inner frames was quite easy seeing as they were so rusty. They have a rubber strip that is glued to the glass and then the frame is pushed over the rubber with a little adhesive to hold it all in place.
Easiest way to remove it is tap it with a hammer, sliding the hammer head on the pane of glass so as not to have any accidents and smash the glass.
Mine broke in two and once all the old stuff was off I renmoved the glue and cleaned the glass with a Stanley blade and wire wool to get it all clean.
The handles are held on with a little grub screw that was seized so I drilled it out to remove it so I could then undo the nut holding the spigot on the glass.
I now have both of them in the same position so once I get some rivets I will add the next step for those who haven't done this yet.
