- May 27, 2010
- 416
- 137
Question for the guys in Oz.
I have a constant problem with the smell of fuel inside the cabin of the car. I knew the ends were connected correctly and there were no leaks anywhere end to end. Tank drain plug was fine as is the seal on the cap.
Long story short, I pulled the fuel line out and all along its length it smells of fuel. I know I did not contaminate it when I pulled it out. (I was sure the hose was the culprit so I plugged the ends up and washed my hands before I pulled it out.) I replaced it with a different brand but the smell remains.
I have come across a couple of threads in other forums that note that others have come across the same issue.
http://www.clubcobra.com/forums/aus...8379-permeation-resistant-fuel-line-hose.html
Rang the guy at Performance Wholesale in Brisbane (they are mentioned in the forum noted above) and he knew exactly what my problem was. Said he had the same issue with a car he restored as had others that worked with him. Apparenlty has to do with something that is added to the unleaded fuel. (http://www.performancewholesale.com.au/index.php)
He suggested either running the line under the car, making up a solid line or using a braided hose that had a teflon coating inside. Anyone else have the same issue and if you have resolved it what did you do?
Joe R
Joe R
