Thread Tools
Old 31-03-2015   #121
New Zealand
Re: 1963 'D' resto with 126
Looks great Roger. Thanks for the tips on seat belts.
What's the best time to tackle these. My car's finished at the panelbeaters and off for a respray soon.
Tim
timgarman is offline Reply With Quote Quote
Old 31-03-2015   #122
New Zealand
Hi Damian. My engine tinware is coated with a type of high performance coating supplied by a nz company called, funny enough, High Performance Coatings! They also do a lot of high temp coatings for exhausts and other car parts. I am sure there will be an equivalent supplier where you are. The finish is textured, a little bit like the Hammerite finish you used to get on old tool boxes etc. I went for that because it hides dirt and the extra thickness dampens reverberation. I guess technically the greater surface area also disperses heat a tiny fraction better too.
Roger
Thanks Paolo66 thanked for this post
RogerNZ is offline Reply With Quote Quote
Old 04-04-2015   #123
Bleeding Knuckles has donated!
Cool Car Rodger - VERY Cool Car !!! good job all round. Mine will, alas, be nowhere near your standard, but I have just got my cooling tinware back from the powder coaters - in a very (in your face) bright Red!!! Tomorrow will be a busy day getting the engine back together and running again. Now, you mention a near miss with your oil piping and the cooler fit can you elaborate please? I have noted the fittings used in your latest pics what type are they? Do you have an accurate figure for bhp at the wheels with your set-up? Thanks.
Ian.
Bleeding Knuckles is offline Reply With Quote Quote
Old 21-09-2015   #124
New Zealand
Hmmmm after 700kms of mostly trouble free running in I was unexpected left stranded last weekend... Keen to hear people's thoughts...
Car ran fine for 5kms or so of across town driving. Then gave a bit of a surge for half a second before losing power and stalling.
Once stopped it coughed a little on the starter but did not start.
After a bit of a look around the engine for any obvious faults it still refused to start.
After a quick coffee - good luck to break down next to a cafe? - the car started but ran for only 2-3 seconds before dying.
Repeat the above while waiting for tow truck.
Once home no start at all.
No spark with new plugs
12.5 volts measured at positive side of the coil - brand new coil
Spare coil fitted, still no spark.
(BTW no fuses blown)
I am starting to wonder if the fancy 123 ignition unit may have failed? A Google search has found the occasional reference to failures but no discription of the circumstances.
It is the 123 which outwardly mimics the original distributor, so I was able to take off the cap and check that the rotor is turning when the engine turns over.
If anyone has any ideas I'd be happy to hear them!
Roger
Old 21-09-2015   #125
stevehg has donated!
Assuming you haven't developed a dodgy earth connection, it appears it could only be the 123 unit or the leads at fault.
cheers, Steve
stevehg is offline Reply With Quote Quote
Old 21-09-2015   #126
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
Quote Originally Posted by stevehg View Post
cheers, Steve
My thoughts exactly - you have power to the coil but no spark can really only mean a bad earth or this 123 unit thing (or distributor on a car without that box)
Charmander - Panda Mania 1242 mpi 8v - thread
Sully - 500 1.3 Mjet - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 01-01-2017   #127
Hi. Roger Happy new year by the way.What a fab restoration .I have just finished mine and drove for the first time.Everything was ok but OH the steering play.I have tried to adjust but no joy.I have just managed to buy a 126 rack,so will be doing the same conversion as you.Just one question do you use the 126 rack as is or do you have to change the ends.I thought I had done a good restoration but yours is way better than mine.
Thanks Bryan
phoenix1 is offline Reply With Quote Quote
Old 17-02-2017   #128
i had the same thing with mine and it was the 123 infact i went through 2 of them before going back to points and has beed perfect ever since
Likes fiat500 liked this post
only1stefan is offline Reply With Quote Quote
Thread Tools
1963 Spider Pinanfarina euronatura Newbie Central 3 23-02-2008 14:38
1963 Pininfarina Spider Convertable euronatura Lets Talk FIAT 0 22-02-2008 18:10
