I've decided to purchase a new Polish 650 motor and syncro transmission. I should have them in about a month and plan to replace the 500cc motor and crashbox in my 69 500L. The new motor includes the starter but I understand the starter on the 650 is the solenoid type as opposed to the pull type on the 500. I've heard that the easiest thing to do is add a pushbutton for starting but was hoping to keep the lever as the means of starting the car. Any thoughts or ideas would be appreciated. If the pushbutton is the only way to go any thoughts on wiring that up would be appreciated as well. I also haven't found much info on hooking up the heating ducts other than having to bend one a bit to make room for the starter motor. I'm trying to get all the info I need for the swap in the month I'm waiting for the engine to arrive. The engine is supposedly complete (gearbox, clutch, starter, driveshafts, ignition, fuel pump, carb, alternator, etc.). Thanks in advance.
