martinmerc
In my previous post - described how 500 will not get to high rpm. If you try to rev it (even with no load), then at about 3000RPM - it stumbles and loses rpm, then will increase rpm up and down - never staying at high rpm. Suggestions were: ignition - I replaced points , condenser, cap, rotor, static and dynamic timing set. - no effect. Another suggestion was float level low - removed and checked - OK also plenty fuel in bowl so I doubt that pump is bad. No effect.
I am out of ideas. Any other ideas?
