I find that my oil light on speedo meter works even though the wire going to the oil pressure plug on engine is taken off, does anyone know why this is or is the oil light controlled from somewhere else?
Hi Shanil
As far as I know, the oil pressure sensor actually breaks the circuit when it operates (under oil pressure) which makes the warining light go out.
Therefore it would be correct that the light would come on when you pull the wire off.
All this indicates to me that your oil pressure sensor is faulty.
Hi Oppsadaisy, the oil light goes off as well when I raise the accelarator, I will change the oil plug sensor but the light really shouldnt go out when the engine speed increases ssince the oil plug wire is pulled off
Should I check the wiring?
Definitely! It sounds like the wiring to battery charge warning light and the oil pressure warning light may have been switched.
With the old dynamo on the original 500 engine, (pre alternator) the charge warning light would come on at idle and go off when the engine RPM increases.
With the wire to the oil pressure sensor disconnected, it should be impossible for the oil pressure warning light to work at all.
Good luck!
Thanks got the wiring checked and seems there was some wiring problem but now I find the oil light comes on during ignition but goes off completely and does not come on when engine idling which used to happen in the past is this normal?
Yes that is perfectly normal.
In fact if it did come on on idle I would suspect a problem with the oil
pump.
By the way Shanil, I was in Lanka just before Christmas two years ago - it was very odd to see Christmas decorations in the Colombo Hotels and it was 32 degrees outside!
