FIAT Auto Specialist Team
Thread Tools
Old 3 Weeks Ago   #1
USA
Master Cylinder-to-reservoir hoses
Hey folks, so I'm working on the master cylinder for a '69 124 and I'm a little confused. There's a pair of rubber hoses that run from the master cylinder reservoir to the master cylinder itself, on the one hand, where can I even find rubber brake hoses without fittings on the ends, and on the other, how am I going to find hoses with a 1/4 inch opening on the one side and a 1-inch opening on the other? the old hoses have completely perished with age, is there a simple solution to this problem? any insight you can give would be helpful.
70mstang is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Thumbs up Re: Master Cylinder-to-reservoir hoses
Quote Originally Posted by 70mstang View Post
Hi, rubber hoses from a reservoir to the master cylinder are not under hydraulic pressure and only serve to top up the master cylinder as the brakes wear down. You can use reinforced fuel line pipe and to get over the size difference you can use water plumbing copper reducing fittings. I hope this helps you.
cotswoldtony is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Hi, Welcome to the FF.
The hoses from the reservoir to the master cylinder are single diameter. When it was sold by Fiat, they sold it by the metre.
Name:	67 Brake Master Cylinder.gif
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
USA
Odd, I wonder when this one got such a weird setup, the reservoir tank is yellow enough to be stock.
Thread Tools
(G) Wanted: brake master cylinder and reservoir aquamarine Panda (Classic) 6 03-06-2017 22:24
(T) Master Cylinder ReKone 500 (Classic) 4 20-02-2017 01:04
(T) Grande punto master clutch cylinder/slave cylinder Ramrodd Grande Punto 0 31-07-2013 17:43
master cylinder whitek75 Tech Talk 1 16-03-2011 10:36
(G) Brake master cylinder reservoir not playing lewey Panda (Classic) 7 04-11-2007 16:28
