Thread Tools
Old 3 Weeks Ago   #1
USA
Battery Charging Issues
1976 Spider 124: The alternator is outputting 15 volts, but it is not charging the battery (brand new). When car is started, it will continue to run with the battery disconnected. Battery is not charging when connected. Since the alternator is outputting 15 volts, is there a voltage regulator? If so, where is it located? Is there a source for a wiring schematic?
fiat76 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Battery Charging Issues
Editing this because I was wrong Davren is correct.
Humble apologies.
the voltage at the battery with engine running should be around 13.5 volts up to 14.8 volts is fine.
Disconnecting an alternator with the engine running is likely to destroy the voltage regulator.
If you want have your new battery checked sometimes even new batteries are duff.
How do you know battery not charging?
jackwhoo is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by fiat76 View Post
Hi, Welcome to the FF.
1975 and 1976 models have an external voltage regulator (item 10 on the diagram below). If it's not there, the charging system may have been modified to an internally regulated alternator.
1975 and 1976 models also have a charge indicator light relay (item 7). Internally regulated alternators don't need that relay.
EDIT: For some reason, I can't upload the diagram. The external voltage regulator is in front of the relays mounted on the left front inner wing. It should have 2 terminals on it, labelled 67 and 15.
Thanks jackwhoo thanked for this post
Likes jackwhoo liked this post
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
USA
Thanks, Davren, for your quick reply. When I get back to the garage, I will check things out again!
***** I am pretty sure there is not an external voltage regulator, but I will check again! The alternator appears to be new, so perhaps it was modified at some point in time.
1975 and 1975 [do you mean 1976?] models also have a charge indicator light relay (item 7). Internally regulated alternators don't need that relay.
*****Is there a link to the diagram you could send to me?
Old 3 Weeks Ago   #5
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Yes... typo. Corrected it now.
No.... it's just a scan from the Spider workshop manual. I'll upload it here when the forum administrator has fixed the problem.
Old 3 Weeks Ago   #6
It is a common upgrade to fit alternators from later spiders that have an integral voltage regulator.
Old 3 Weeks Ago   #7
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Upload problem fixed. Here's the diagram.
Name:	Spider Relays.jpg
Old 3 Weeks Ago   #8
USA
Quote Originally Posted by Davren View Post
Many thanks!
Old 3 Weeks Ago   #9
USA
Quote Originally Posted by jackwhoo View Post
Humble apologies.
I use a meter on the battery to determine it's not charging.
Old 3 Weeks Ago   #10
Are you measuring the voltage at the battery terminals with the engine running?
If yes what is the voltage you are reading?
Old 3 Weeks Ago   #11
USA
Yes, I am measuring the battery terminals with the engine running and I get a reading of 12.4. I use a clamp on meter to measure the current from the alternator to the battery and I get no reading. There is no current flowing into the battery.
Old 3 Weeks Ago   #12
USA
Smile Re: Battery Charging Issues
When we measure output at the alternator, it's 15 volts (14.9) with the battery connected. When we disconnect the battery, the engine continues to run (means the alternator is supplying the energy for the spark...lights work.....it's just not charging the battery. I have to determine if there is a separate voltage regulator and if there is, where is it located. IF the alternator that had been put in has a built in regulator, must I bypass the original voltage regulator. Work was previously done years ago, and car is not run frequently.
Old 3 Weeks Ago   #13
USA
Many thanks, Gentlemen, for your help!
Old 3 Weeks Ago   #14
Ah it looks very much that there is a problem in the main wire from the alternator (where you measured 15v) and the battery where you measured 12.4v.
If the wire is good the voltage at the two points must be the same.
Do not run the car with battery disconnected.
Old 3 Weeks Ago   #15
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Are you using a DC only or AC + DC amp clamp? The much cheaper AC only clamps won't measure DC.
Are you clamping it around only one of the main battery cables? Clamping it around both cables will cancel out any reading.
As suggested above, it's not a good idea to run the alternator with the battery disconnected. It can cause serious damage to the alternator diodes.
It's a large black or grey box fitted under the bonnet (hood) similar to the picture below. If it's there, you can't miss it.
If it's been modified to the later internally regulated alternator, the external regulator would have been removed. You should be able to see wiring modifications where the external regulator was mounted.
Are you sure it's a 1976 car, and not a later one? Several members on here have been confused as to which year there Spiders are. The identification pages below should confirm which you have.
You may also get some clues from the diagram of the two different alternators for the up to, and post 1976 models from the parts catalogue.
ID:	181766   Click image for larger version
Name:	01 Model Identification 1.jpg
Name:	02 Model Identification 2.jpg
ID:	181769   Click image for larger version
Name:	81 Alternator A.gif
Thread Tools
(G) Battery Not Charging? umanemo Ducato 11 22-05-2017 10:50
(T) Punto POP red battery light....battery is charging. Eireannbaker Other Fiats 3 10-11-2016 14:22
(T) Alternator ok, battery ok, battery not charging marc4242 Cinquecento / Seicento 7 25-07-2013 13:26
(T) Seicento Sporting 1108 Battery Not Charging Battery Light On SmithSeicento Cinquecento / Seicento 0 30-08-2012 00:02
(T) Charging Issues 86CalX X1/9 4 10-03-2007 21:53
