Lamps by Post - For all your lighting needs
Thread Tools
Old 20-04-2017   #1
USA
Exclamation Help!
Hello all,
Might be a stupid question. But does anyone know how to get the dang long bolt out of the smog/air pump? The valve is broken and one of the hoses has a hole. So I removed all the other items and plugged the hole. But I tried to get the pump off and I could get the adjustment bolt off and the top bracket, but when I tried to get the bottom longer bolt out after taking the nut off I was unable to. The pulley seems to be in the way. I tried to just take the whole bracket off the block, but the nuts are on very very tight! Any help would be great!
1980 Fiat Spider 2000 Carb
cazman13 is offline Reply With Quote Quote
Old 20-04-2017   #2
Re: Help!
I have no idea if this possible but could you cut the head off the bolt and pull it out from threaded end?
Fit replacement bolt other way around ie nut at pulley end.
Likes cazman13 liked this post
jackwhoo is offline Reply With Quote Quote
Old 20-04-2017   #3
USA
Re: Help!
Quote Originally Posted by jackwhoo View Post
Thanks! I am going to see if I can get the pulley bolts loose before I go cutting anything just yet. But my have to resort to that. I am just removing it off the vehicle. So I won't be putting one back on.
Thanks jackwhoo thanked for this post
Old 21-04-2017   #4
USA
Re: Help!
I was able to get the pulley bolts loose and then get the pump off. Then I removed the two nuts holding the bracket to the block and bam it was off.
Thread Tools
