Hello all,
Might be a stupid question. But does anyone know how to get the dang long bolt out of the smog/air pump? The valve is broken and one of the hoses has a hole. So I removed all the other items and plugged the hole. But I tried to get the pump off and I could get the adjustment bolt off and the top bracket, but when I tried to get the bottom longer bolt out after taking the nut off I was unable to. The pulley seems to be in the way. I tried to just take the whole bracket off the block, but the nuts are on very very tight! Any help would be great!
1980 Fiat Spider 2000 Carb
