Thread Tools
Old 18-04-2017   #1
USA
Exclamation Fuel line help please!
Hello All,
I have a 1980 Spider that was leaking fuel and finally pin pointed it. It is the metal line that runs inside the car next to the drivers seat. I am not the best at this stuff. I would think I could just cut out the section and replace it with a section of rubber fuel line? I would need to cover it up I'm sure so it doesn't get stepped on and such. But if I buy rubber hose and use hose clamps will that work? I know it is not the best fix, but for now I would hope it will work.
Thank for the advice!
cazman13 is offline Reply With Quote Quote
Old 20-04-2017   #2
Ireland
Re: Fuel line help please!
Ideally you should fit a complete new fuel line, for safety reasons. I don't think I've ever seen an original fuel line with junctions inside any car.
Having said that, it's a biggish job to fit a one piece fuel ine into a car, ideally done when the engine and interior trim is out.
What you suggest will likely work fine but I'd urge you to use the best materials/techniques available. Maybe ask at an Auto Factors or similar for advice. There might e.g. be available compression type fittings suitable for use with fuel so you could repair the pipe or let in a new section of metal pipe (tube).
I've seen metal fuel pipes repaired by soldering/brazing/sleeving but all these methods require heat. Some might suggest using epoxy resin or similar but I'd don't know.
Best not to take any chances where fuel is concerned. If your car is fitted with an electric fuel pump (I think it is) then the line will be under pressure any time the engine is running.
Also, if any fuel has soaked into the soundproofing mat under the carpet, then this should be removed.
Have you gotten a fire extinguisher yet? As I said previously, it's a good idea to have one in an old car.
Al.
Likes cazman13 liked this post
The more you know, the less you need.
If what I write is helpful please click on the 'thanks' button, (smiley face on lower right).
F123C is offline Reply With Quote Quote
Old 20-04-2017   #3
USA
Quote Originally Posted by F123C View Post
Al.
Thanks! I took the old metal lines out and replaced them with new metal lines and replaced the rubber lines on the end at the same time. No more leak. Now to get rid of the fuel smell.
Likes F123C liked this post
Old 22-04-2017   #4
Ireland
Quote Originally Posted by cazman13 View Post
Excellent!
Maybe you won't need the fire extinguisher after all!
The sound deadener mats can hold the smell of fuel even after drying.
Also, the bitumen/tar sound deadener coating stuck to the floor sections can hold fuel residue underneath and therefore the smell of fuel for some considerable time. Try pressing on it to check for soft spots.
Al.
Old 24-04-2017   #5
USA
Thanks Al for all the info!
Thread Tools
(T) Fuel line Robot Barchetta 13 03-01-2016 10:04
(T) Fuel line RedBravoTjet Stilo 2 02-01-2015 18:53
(T) 2007 Ducato 2.3 Fuel line to fuel filter connectors marano Ducato 0 16-08-2013 21:41
(G) gt fuel line !!!! dellboy Punto (Mk1) 2 13-12-2008 00:02
which is the fuel in line? tom FIAT Boo Archives 1 09-11-2006 22:46
