Lamps by Post - For all your lighting needs
Thread Tools
Old 04-04-2017   #1
USA
Question car shuts down when warm
80 fiat spyder fuel injected runs great but not for long when car get hot and fan turns on car shuts down does anyone ever have this problem or know what would cause this after it cools starts right up would appreciate any help thank you
bandette10 is offline Reply With Quote Quote
Old 10-04-2017   #2
Ireland
Re: car shuts down when warm
Sounds like the ignition coil or ignition module (if fitted) is overheating. Iirc, the coil is on the left inner wing and gets blasted by hot air when the radiator fan switches on. This doesn't affect the coil normally but might just tip a dodgy coil into failure.
Next time it happens, try cautiously touching the coil and see if it's boiling hot. It shouldn't be too hot to touch. Try cooling the coil with compressed air or a water spray, then dry off and try starting the engine.
Al.
The more you know, the less you need.
If what I write is helpful please click on the 'thanks' button, (smiley face on lower right).
F123C is offline Reply With Quote Quote
Thread Tools
(T) Engine shuts off and car won't start Robotsatemyarms 500 (USA) 10 30-06-2016 19:29
(T) car slow to warm up tlo Punto (Mk2/2b) 3 05-10-2015 22:07
(G) Headlight suddenly shuts off, central locking opens but car runs!!! chakraborty Palio 1 28-09-2011 06:48
(T) 79 Spider- radio shuts off then car stalls phillykw 124 Spider (Classic) 14 08-12-2009 17:09
car will not start when warm rob from devon FIAT Boo Archives 2 11-07-2003 19:33
