Hi folks. I have a 1978 Fiat Spider 124. It is parked at my dad's ranch, which is about a two hour drive from my house. I'm trying to get it up and running again so I can see about bringing it home to start restoring it.
I've had it running a few times over the past several years, but each time it runs maybe 10-15 minutes and then the ignition coil fails. So far I've been putting in cheap coils from the local Autozone or Oreilly. I haven't wanted to spend the money for a genuine Marelli coil until I can figure out what the underlying problem is. (But, maybe that IS the underlying problem?)
The most recent time I tried to start it, I used a cheap Autozone coil. I had 12V at the coil with points closed (dropping off to 8 or 9 volts when cranking). No spark generated at all.
The time before that I had an old coil off of an old Ford farm trunk my dad had at the ranch. That time the Fiat started up and purred like a kitten for about 15 minutes until the coil sprang a leak and all the oil boiled out (I think I nicked it pulling it off the truck).
I've had at least 3 coils in it before this that have either not worked at all, or have run for 10-15 minutes and failed.
The parts stores sell two coils - one WITH and one WITHOUT an internal resistor. I'm never sure which one to purchase, and I think I've tried both. I've attached a picture that shows a small cylinder that attaches to the coil. I'm not sure if this is an external resistor, or just some sort of RF filter for the radio.
Any hints would be greatly appreciated.
Steve
Steve
