Could be many things but I would start by cleaning every electrical connection and ground including the fuses. When clean, coat with dielectric grease before reconnecting - the electrical connectors in these cars a infamous for corroding and causing a myriad of problems; once cleaned and protected they will be good. Secondly, the turn signal switch in the steering column may be bad. Finally, the emergency flasher switch (not the flasher itself) may be bad.
