Keystone
My Spider idles well and it runs well above 1500 RPM. Idle when warm is 1000 RPM. When idling, if I slowly depress the accelerator, I am likely to stall the engine. If I hit the pedal hard, the engine responds quickly. Sometimes that will produce a slight hesitation before the engine races. When warm the engine is very drivable.
When cold, the problem is particularly bad. I have to keep the revs up to avoid stalling. When cold the idle is about 500 RPM.
One issue to consider is this car sits a lot, sometimes a month at a time. I use fuel preservative and sometimes add some carburetor cleaner (Seafoam) to the gas.
Do these symptoms ring any bells?
