Thread Tools
Old 05-08-2009   #1
USA
Engine Block Coolant Drain Plug
I'm flushing the cooling system, and was wondering a few things. First off, can i get away with just draining it from the radiator and hoses, do i need to also drain it from the drain plug on the engine block?
Second, is the plug in this picture the plug I use?
And lastly, are there any torque specs when i replace that plug?
ID:	66834   Click image for larger version
flare is offline Reply With Quote Quote
Old 28-08-2009   #2
USA
Re: Engine Block Coolant Drain Plug
are you just flushing and refilling the cooling system? try this...
1. add a t-fitting from a flush kit to the heater hose that goes from the heater core to the center of the head.
2. turn heater control valve open
3. hook a garden hose to the t-fitting
4. open petcock at the bottom of the radiator, and remove lower rad hose
5. turn water on and flush with impunity
Mike Bouse
[EMAIL="mbouse@chartermi.net"]mbouse@chartermi.net[/EMAIL]
Coldwater, Michigan USA
Home of the [B][COLOR=red]Michigan SHORTER SHIFTER[/COLOR][/B]
member, Fiat Lancia Unlimited
mbouse is offline Reply With Quote Quote
Old 31-08-2009   #3
USA
Thanks for the advice!
Thread Tools
(T) Gearbox oil change; drain plug & fill plug? combwork Multipla 3 03-07-2009 09:50
(G) Water drain plug? alanwylde Ducato 0 04-01-2009 13:49
(G) Marea 1.9td 100 engine oil drain plug graemechalmers Marea 2 07-12-2008 17:02
(T) Gearbox drain plug on '99 mk.1 ? wavestar Punto (Mk2/2b) 3 01-01-2008 21:45
(T) Oil drain plug weyeye Cinquecento / Seicento 2 12-07-2005 16:19
