POSTING GUIDELINES
This Forum is for Stilo enthusiasts or anyone else looking for support. If you need help with a specific issue then take a look in the Guides and FAQ sections (at the top underneath the Forum logo).
If you're looking for help with diagnosing a problem then your best friend is the Search tool (on the Red menu). It's well worth using this in Advanced mode to help narrow down search results.
Note: Search results that have [....] in the title means there's a final resolution to the thread with the solution given between the brackets
If you find a thread that solves your problem then why not tag a reply on the end to let us know. You might also want to click on the Thanks button
If you've found a post that mentions the same problem you're having but you're still stuck then post a reply with as much detail as you can (don't forget to mention which model and engine you have
Got an issue no one's mentioned before - then start a NEW THREAD as we'd love to hear about it.
FORUM DON'Ts
Don't Double Post - post in the correct section and if you don't get a replay within say a week then try 'BUMPING' the thread.
Don't Blind Post - This is reading the very 1st post and then leaving a reply without bothering to check what anyone else has said. If the answer's already been given then you're wasting not only your own time but everybody else who takes the trouble to read your post. If want to agree or disagree with what's been said before then that's fine (that's the whole point of the Forum after all! )
Don't Shout - this is using ALL CAPS
Don't use non-standard English - If you can't be bothered to string a sentence together then don't be surprised if no one is bothered to reply either. However, if your first language isn't English then don't worry too much - just post what you can as we'd still like to hear from you
